TwinTurbo.NET: Nissan 300ZX forum - BTW. The timing numbers change because
kickerzx
on December 18, 2009 at 1:46 PM
Did you do any work on the car before this happend?
posted by kickerzx
on December 18, 2009 at 01:40 PM
the ECU hits a different cells in the map. Do you have a wideband in the car? would be intresting to se what the AFR was during this..
Which System Faults will make the ECU take over the timing
MaxxAction
08:45:33 12/18/09
kickerzx
13:40:16 12/18/09
BTW. The timing numbers change because -
kickerzx
13:46:12 12/18/09
Re: BTW. The timing numbers change because
MaxxAction
15:00:21 12/18/09
Re: Did you do any work on the car before this happend?
MaxxAction
14:56:08 12/18/09
I agree with kickerzx ......
zx299
15:27:03 12/18/09
I see.. Well either i think you may have bad o2`s that
kickerzx
17:30:15 12/18/09
Re: I see.. Well either i think you may have bad o2`s that
MaxxAction
18:09:01 12/18/09
ok. In that case i picture a scenario where it ran good..
kickerzx
18:14:01 12/18/09
Which again leads me to a chip that dont fit your setup (n/m)
kickerzx
18:17:51 12/18/09
O2 sensors play NO part in idle.....
zx299
19:22:39 12/18/09
i don't disagree with you but can you please explain why
surfer31337
00:02:01 12/19/09
No thats not correct. O2`s DO play a role at idle.
kickerzx
05:50:38 12/19/09
Look at the pics of the maps on Ash`s site.
kickerzx
05:55:22 12/19/09
Incorrect.......
zx299
15:00:43 12/19/09
Hm. I am on the verge of giving you this one.
kickerzx
17:26:13 12/19/09
