TwinTurbo.NET: Nissan 300ZX forum - Re: Z has too much freeplay in the clutch pedal and it somet
craigz96tt
on December 18, 2009 at 11:54 AM
Z has too much freeplay in the clutch pedal and it sometimes
posted by surfer31337
on December 17, 2009 at 08:18 PM
you can try to bleed and adjust rod behind clutch pedal but grind
into 4th will still be there. standard equipment on Z's due to
weak alloy used in synchros
surfer31337
20:18:14 12/17/09
Adjust freeplay to proper setting and bleed the system>>
ZUL8TR
06:04:28 12/18/09
Re: Z has too much freeplay in the clutch pedal and it somet -
craigz96tt
11:54:32 12/18/09
4th grind not standard with my 92 NA Z. Getting the >>
ZUL8TR
08:12:01 12/19/09
This is something you can do yourself (inside)
Tom B (AZ)
08:46:39 12/21/09
