TwinTurbo.NET: Nissan 300ZX forum - One thing I found
Subject One thing I found
Posted by Stadsport (PHX) on December 17, 2009 at 8:38 PM
  This message has been viewed 207 times.
In Reply To Running out of time to get Z sorted out posted by LJZTT on December 17, 2009 at 05:38 PM
Message With my car, I did a plenum pull and upon reassembly, I idled
between 1500 and 2000 RPM. All vacuum lines were hooked up.
When I started doing some research, I found that they were
hooked up incorrectly.
I drew up a vacuum diagram which is in the auto FAQs. In
retrospect the only inaccuracy is I swapped the colors of the AIV
and EGR solenoid connectors, which I assume are no longer an
issue for you. My problems stemmed from the vacuum lines
running to the carbon canister, the recirc valves, etc. The lines
in that area were all mixed up.
