TwinTurbo.NET: Nissan 300ZX forum - Are all six are soaked?
CaliguyPurdue (Selin Design)
on December 17, 2009 at 11:20 AM
Fuel lines are straight. The plugs are soaked...
posted by Andrewhuffman
on December 17, 2009 at 10:15 AM
I once had a broken fuel damper and when they go they spew fuel into the passenger side plenum. If you haven't already give the cylinders a chance to dry out a bit.
www.selindesign.net
New motor wont start.
Andrewhuffman
09:15:09 12/17/09
Are the plugs soaked from gas? (n/m)
Josher
09:22:25 12/17/09
Sounds like your plugs are fouled, also check if your maf
Ice95z
09:42:23 12/17/09
check to see if you reversed the fuel line by accident
NobleZ
09:49:55 12/17/09
Andrewhuffman
10:15:28 12/17/09
Are all six are soaked? -
11:20:12 12/17/09
changed the MAF, changed PTU.
Andrewhuffman
10:31:36 12/17/09
did you check the CAS? also, did you change the fuel filter?
NobleZ
10:52:26 12/17/09
Try posting in the technical forum. Its why its there. (n/m)
z32z
11:42:24 12/17/09
This is the technical forum . Technically speaking ! (n/m)
xteam300tt
13:32:22 12/17/09
This post was in the General forum before it was moved here. (n/m)
NytWolf
17:25:52 12/17/09
Recheck your timing belt
NytWolf
11:43:41 12/17/09
all 6 were soaked. new fuel filter. checked CAS.
Andrewhuffman
15:33:17 12/17/09
You're not listening nor do you comprehend a 4-stroke motor (n/m)
NytWolf
16:54:26 12/17/09
The timing belt is not wrong!
Andrewhuffman
17:11:02 12/17/09
LOL -- How do you know it's not wrong?
NytWolf
17:21:29 12/17/09
Re: LOL -- How do you know it's not wrong?
canyoncarver
22:13:46 12/18/09
It Lives!~!!!
Andrewhuffman
18:16:20 12/17/09
Re: It Lives!~!!!
Andrewhuffman
19:11:32 12/17/09
vid
Andrewhuffman
18:32:06 12/17/09
Re: vid
ZTurboFan
18:41:12 12/17/09
vid
Andrewhuffman
18:54:48 12/17/09
Re: vid
ZTurboFan
19:01:49 12/17/09
Re: Re: vid
Andrewhuffman
19:12:21 12/17/09
No exhaust...
ZTurboFan
19:40:43 12/17/09
Re: No exhaust...
Andrewhuffman
20:04:11 12/17/09
Re: Re: No exhaust...
ZTurboFan
20:20:30 12/17/09
Re: Re: Re: No exhaust...
Andrewhuffman
23:29:29 12/17/09
Well...
ZTurboFan
00:39:36 12/18/09
Re: Well...
Andrewhuffman
11:12:20 12/18/09
Update
Andrewhuffman
14:31:23 12/18/09
Like I said, timing issue
canyoncarver
17:10:04 12/18/09
Timing
ZTurboFan
19:48:11 12/18/09
Re: Timing
Andrewhuffman
01:27:33 12/19/09
Re: Re: Timing
Andrewhuffman
01:28:47 12/19/09
Assumptions...are...BAD
ZTurboFan
10:55:21 12/19/09
Re: Assumptions...are...BAD
Andrewhuffman
14:09:29 12/19/09
Next Steps
ZTurboFan
16:06:12 12/19/09
Re: Next Steps
Andrewhuffman
20:37:50 12/19/09
1 Year+
ZTurboFan
21:40:21 12/19/09
Timing
Andrewhuffman
11:18:05 12/20/09
Ok. Good.
ZTurboFan
11:49:58 12/20/09
Update
Andrewhuffman
13:51:01 12/20/09
Imprint, not inpring.
Andrewhuffman
13:56:11 12/20/09
#1-90, #3-60, #5-90
Andrewhuffman
14:02:07 12/20/09
Re: #1-90, #3-60, #5-90
ZTurboFan
14:29:26 12/20/09
Re: Re: #1-90, #3-60, #5-90
Andrewhuffman
14:39:43 12/20/09
That's a bummer...
ZTurboFan
16:41:00 12/20/09
Re: That's a bummer...
Andrewhuffman
20:45:24 12/20/09
Well...one more...
ZTurboFan
09:36:27 12/21/09
Update
Andrewhuffman
14:18:06 12/21/09
Re: Update
Andrewhuffman
14:33:22 12/21/09
My Thoughts...
ZTurboFan
15:27:14 12/21/09
Re: My Thoughts...
Andrewhuffman
15:53:29 12/21/09
Lifter Rebuild
ZTurboFan
22:13:39 12/21/09
Oh, and good on the cams
ZTurboFan
22:15:40 12/21/09
It Lives!~!!!... again
Andrewhuffman
19:57:11 01/01/10
WTF you are an idiot. This assuming
dream Z (MD)
02:37:57 01/02/10
Re: WTF you are an idiot. This assuming
Andrewhuffman
06:03:19 01/02/10
Get a bigger computer screen.
dream Z (MD)
11:41:00 01/02/10
