TwinTurbo.NET: Nissan 300ZX forum - Re: I installed the same rods and boots.
Subject Re: I installed the same rods and boots.
Posted by Da Flash on December 16, 2009 at 8:35 PM
  This message has been viewed 124 times.
In Reply To I installed the same rods and boots. posted by Trailboss on December 16, 2009 at 03:49 PM
Message :Just heat up the boots with a heat gun and stretch them over the rod ends gently.
Thanks for the reply!!
That should work but, you would think that they would've made a little easier to install! The hole that I have to stretch is only 1/2" in diameter but the ball joint end is 1-1/2" in diameter. It appears that once you install the boot, inspecting the ball joint is going to be at least difficult.
