TwinTurbo.NET: Nissan 300ZX forum - Check coolant temp sensor, and fuel temp sensor.
Subject Check coolant temp sensor, and fuel temp sensor.
Posted by LiL B on December 15, 2009 at 5:10 PM
  This message has been viewed 226 times.
In Reply To Re: well.... posted by twooton on December 15, 2009 at 10:06 AM
Message DO you have any ECU codes from a self diag?
My brother NA had a very similar situation two weeks ago. Car was
running fine no indication of anything wrong then next morning car would
not start. It would crank fine but instant you let of the ignition the car
would die. In other words never turn over similar to what your
describing. THere was NO codes coming from the ECU which was
puzzling.
Remedy was testing the temp sensor with a working one... fired up like a
dream. So if you have access to a known working coolant temp sensor
and fuel temp sensor give those a whirl.
