TwinTurbo.NET: Nissan 300ZX forum - Seems obvious...
Seems obvious...
ZTurboFan
on December 14, 2009 at 3:34 PM
wuth the maf and ds o2 sensor connected, the car idles
posted by arkansasturbo
on December 14, 2009 at 02:11 PM
That this is at least some of the problem! :-) Hopefully it is all of the problem and once that o2 sensor is fixed up, it'll work for you. Good luck.
STILL having post plenum pull issues...
arkansasturbo
19:56:44 12/13/09
Have you preformed a normal boost leak test? (n/m)
jobambo
20:09:33 12/13/09
Re: STILL having post plenum pull issues...
ZTurboFan
20:22:16 12/13/09
Have performed multiple boost leak tests, all good
arkansasturbo
20:39:20 12/13/09
Just so I understand...
ZTurboFan
21:15:31 12/13/09
That is correct
arkansasturbo
21:22:44 12/13/09
Here's the weird thing...Runs perfect with 02 sensors unhook
twinturbineZ
23:34:02 12/13/09
I think i might know what it is
jobambo
05:17:03 12/14/09
arkansasturbo
14:11:48 12/14/09
Seems obvious... -
ZTurboFan
15:34:35 12/14/09
craigz96tt
08:58:50 12/14/09
Yeah, maybe compare BlaZt logs...
ZTurboFan
09:42:27 12/14/09
Well I just got back from out at the Z...
arkansasturbo
17:07:56 12/14/09
Did you ever swap a 555 ecu? While it could be the O2
doug8867
07:35:22 12/15/09
no i haven't yet, although i find it unlikely that the two
arkansasturbo
12:32:01 12/15/09
