| Do you mean checking the injector itself for resistance? The LED is used to install into the harness connector to see if the ECU is actually firing the circuit or not - it isn't a test of the injector itself.
[ ashspecz.com ] [ agpowers@bellsouth.net ] Enthusiasts soon understand each other. --W. Irving. Are you an enthusiast? If you are out to describe the truth, leave elegance to the tailor. Albert Einstein
