just replaced the lower and upper manifold with two perfect units. Did so because my old lower manifold was stripped in all bolt holes and I assumed it was not sealing the gasket because of this reason. I installed the two new pieces with all brand new oem gaskets. transfered over fuel rails but reused the insulators in between the rails and lower manifold. I seem to have a boost leak when pressurizing the intake system that seems likes its coming from the center of the manifold but I cant seem to find it. It is a slow leak as the intake system will hold the pressure and i can boost about 14psi on low boost. haven't been able to monitor boost close enough to watch it drop off but I am sure it does as I can hear the pshhhhh sound on testing. I can see the plenum gasket sticking out around all the edges of the two mating surfaces so I cant imagine it to be the cause. What else could be leaking and is there a definitive way to check what is leaking. I assume spraying water and looking for bubbles will be the only way, but hard to aim water down in the manifold mating area precisely.
