TwinTurbo.NET: Nissan 300ZX forum - timing readings...
Subject timing readings...
Posted by pearllady91 on December 08, 2009 at 7:26 PM
  This message has been viewed 147 times.
Message Hi, just wanted to know something. If at normal operating temperature, Consult tells me timing is at 15, does that means I would have to adjust CAS so that my timing light indicates 15 degrees??? cause when pick up is on the black loop of the PTU, the timing is around 22-23 degrees. Could that explain rough idle.....thanks
