| Message |
:It's behind the dash; the brake booster is on the engine bay's :side of the firewall. :Try having a friend squeeze their lines in the engine bay while :you sit in the car to see if it goes away. There are two large :lines on the driver's side of the plenum; one goes to the brake :booster, one goes to the clutch booster.Stadsport, I think you could have hit the jackpot (and I just read your post and have yet to do the test). Reason being, the clutch was chagned at the dealer in 2007 (along with the turbos, etc..) and was said to be stock, but it has an extremely heavy pedal! The PO thought it must be a performance clutch and the thought the P-PO must have brought an aftermarket one to the dealer to install. Good thinking all. Thank you! I'll let you know what I figure out this evening. Craig
