Trying to figure out this homemade boost control on this car. It has hoses coming from intake which t's into a setup which is a bolt going into a female end which has a spring inside. This has a hose that t's into two hoses which go supposedly to two other hoses that control the wastegates. Ive noticed if the bolt is tightened I'm getting 9lbs of boost. If i loosen about halfway out I get about 15lbs of boost. The previous owner said it will produce about 22lbs of boost if the screw is out all the way but not to drive the car everyday like this. Question is, with the car having the upgraded jim wolf turbos, jw pop charger, and only other modification is the hks exhaust, how much horsepower is being produced at 9lbs, 15lbs, and 23lbs of boost??? Not familiar with all this at all! Any help would be appreciated!
