TwinTurbo.NET: Nissan 300ZX forum - When I had a pinched o-ring, I found it by doing the power
DavezTT
on December 07, 2009 at 7:59 PM
GAS COMING OUT OF EXHAUST?? Help please.
posted by dc_silver_dc
on December 07, 2009 at 04:42 PM
balance test. Or check your plugs, as they should be soaked. If its leaking that fast, your cylinder won't be firing. At least that was it in my case.
dc_silver_dc
16:42:24 12/07/09
One or both injectors replaced is now leaking continuously
oherr
17:22:20 12/07/09
Re: One or both injectors replaced is now leaking continuous
dc_silver_dc
17:54:02 12/07/09
Yes - if the lower o-ring on one (or both) of the
jzack
18:25:15 12/07/09
Re: Yes - if the lower o-ring on one (or both) of the
dc_silver_dc
21:13:12 12/07/09
Sadly once is all it takes... (n/m)
jzack
15:28:18 12/08/09
where was it coming out of the exhaust and are you possitive
KasbeKZ
17:23:55 12/07/09
Re: where was it coming out of the exhaust and are you possi
dc_silver_dc
18:03:08 12/07/09
What brand did you buy? Sounds like pinched o-rings.
ThunderZ
18:22:31 12/07/09
2nd. New O-rings are a must when installing injectors
JustinSCZ32
19:50:12 12/07/09
Here are the two injectors I bought
dc_silver_dc
21:11:26 12/07/09
Those should be fine as long as you have an NA. I still
ThunderZ
23:03:39 12/07/09
The link is in japanese? (n/m)
ZUL8TR
06:59:07 12/08/09
When I had a pinched o-ring, I found it by doing the power -
DavezTT
19:59:41 12/07/09
Re: GAS COMING OUT OF EXHAUST?? Help please.
canyoncarver
20:32:36 12/07/09
Yeah, I agree.
ZTurboFan
00:58:23 12/08/09
After you fix the injector leaks change the oil and filter (n/m)
ZUL8TR
07:00:07 12/08/09
thank you
dc_silver_dc
18:01:45 12/08/09
Wow! You're definitely lucky if you didn't bend a rod. (n/m)
black300zx
11:42:36 12/09/09
off topic, but, how bad did your stomach turn when you saw
JustinSCZ32
15:35:29 12/09/09
