TwinTurbo.NET: Nissan 300ZX forum - Yes - if the lower o-ring on one (or both) of the
Subject Yes - if the lower o-ring on one (or both) of the
Posted by jzack on December 07, 2009 at 6:25 PM
  This message has been viewed 128 times.
In Reply To Re: One or both injectors replaced is now leaking continuous posted by dc_silver_dc on December 07, 2009 at 05:54 PM
Message injectors got pinched during the install, they'll leak gas into the cylinders. The fuel flows around the injector and the upper/lower o-rings keep if from leaving the rail.
Need to get this addressed - too much liquid in a cylinder could potentially cause the engine to hydrolock. Pull both injectors, install new o-rings, lube everything up really well with petro jelly (both the rings and inside of fuel rail injector cavity) and re-install the injectors again....
