TwinTurbo.NET: Nissan 300ZX forum - Zero compression on all cylinders is very rare. Assuming
Subject Zero compression on all cylinders is very rare. Assuming
Posted by oherr on December 06, 2009 at 2:31 AM
  This message has been viewed 204 times.
In Reply To Car wont start posted by Geronimo77 on December 03, 2009 at 01:46 PM
Message you did the compression test correctly and you really do have zero psi on all 6 cylinders, you could have a cracked block, bent valves, valve cams out of sync with the piston cycles(i.e. timing), blown head gasket (although you should have seen warning signs, i.e. white smoke, etc), etc. etc. Worn/blown piston rings on all 6 cylinders is highly unlikely. Something doesn't seem right, you should have some compression on at least some of the cylinders. Zero compression on all 6 cylinders is highly unlikely. Double check your compression test, make sure you're doing it correctly, and that your compression gauge is working properly. If the readings are correct, it's over for your engine, it's end-of-life. Good luck.
