TwinTurbo.NET: Nissan 300ZX forum - sounds like air in the system, or moisture as stated above
JustinSCZ32
on December 05, 2009 at 6:27 PM
Bad master cylinder??
posted by apepper7191
on December 05, 2009 at 02:41 PM
Since adjusting your pedal didnt help, i would definately bleed the system before you burn up the clutch, and/or wear out the transmission syncros
apepper7191
14:41:13 12/05/09
Have you tried changing the fluid?
Wicked1
16:11:00 12/05/09
sounds like air in the system, or moisture as stated above -
JustinSCZ32
18:27:23 12/05/09
Re: Bad master cylinder??
apepper7191
00:17:09 12/06/09
First did this issue atart after you did the clutch >>
ZUL8TR
09:59:19 12/06/09
No the rear main seal didnt show any signs of leaking
apepper7191
11:20:40 12/06/09
You didn't answer my first question! (n/m)
ZUL8TR
15:42:23 12/06/09
