TwinTurbo.NET: Nissan 300ZX forum - Re: She's vibrating a lot at idle...
Subject Re: She's vibrating a lot at idle...
Posted by Z300Z on August 25, 2009 at 6:29 AM
  This message has been viewed 507 times.
In Reply To She's vibrating a lot at idle... posted by Gerg on August 24, 2009 at 08:52 PM
Message Get the Consult program from a guy in the classifieds called whatsthegoodword. After you get this cable and software hook it up to your Z and check out and see what your ECU is seeing. Plus you can shut off each cylinder 1 by 1 in this program. This is the very first tool you should ever own when owning a Z. It tells you alot. What your TPS is set to what is the voltage of the Alternator o2 sensor readings timing and so on. Once you find the cylinder that is not firing at idle then ohm out the coil packs at .07 and the injectors out at between 10 - 14.
