TwinTurbo.NET: Nissan 300ZX forum - AVC-R Gear based boost setup.
Subject AVC-R Gear based boost setup.
Posted by PiotrC70 on June 29, 2009 at 8:57 AM
  This message has been viewed 455 times.
Message Searched here and on the web and didn't find much. Has anyone set this up? From what I've read, you have to set up the Gear judge first, where RPM's are divided by speed. This is where I have additional questions. Do you go through the gears or pick an RPM in each gear and do the math or does the AVCR figure it out?
I read on another forum that someone recommended doing 3000 RPM's in 1st - 5th gear and do the math to get your gear value. After this is set up, this allows the use of the other AVC-R functions.
"Start Duty" appears to be the gear based boost function I'm looking at and again, from my research, I adjust duty +/- from my target duty in each gear to acheive what I want. In other words, would be example below be a good understanding of how Start Duty works?
Ex: 1st gear would be say -20%
2nd gear would be -10%
3rd gear 0% (Full boost)
4th gear 0%
5th gear 0%
TIA!
