TwinTurbo.NET: Nissan 300ZX forum - Technically, measuring voltage should be fine across the two
Subject Technically, measuring voltage should be fine across the two
Posted by MixManMash on June 24, 2009 at 12:02 AM
  This message has been viewed 141 times.
In Reply To EEEKK posted by Spddracer on June 23, 2009 at 09:12 PM
Message terminals and you won't fry the output transistors on the ECU because a Voltmeter has very high resistance (i.e. it will drop the voltage).
9.5 V should be fine considering the ECU does pulse the injectors so the voltmeter won't read accurate peaks.
But yes, you should check voltage to ground to see that you have battery voltage and there isn't some other issue.
