TwinTurbo.NET: Nissan 300ZX forum - Re: How to replace the OEM control pod lamps with LED lamps.
Subject Re: How to replace the OEM control pod lamps with LED lamps.
Posted by DerHelmz on June 09, 2009 at 1:19 PM
  This message has been viewed 2148 times.
In Reply To How to replace the OEM control pod lamps with LED lamps. posted by DVDBURN (MD) on June 09, 2009 at 12:33 AM
Message Just to be safe, is this right:
Temp Pod (Right):
2) 5mm NEO5-x lamps
1) 3mm NEO3-x lamps
Lighting Pod (Left):
5) 4mm NEO4-x lamps
Bottom of the gauge cluster:
4) 5mm NEO5-x lamps
Is this correct?
And do you know the polarity of the bottom 4 lamps, under the cluster?
