TwinTurbo.NET: Nissan 300ZX forum - You need to install the TT pump onto the 2+2 bulkhead assy.
Subject You need to install the TT pump onto the 2+2 bulkhead assy.
Posted by Bernie (NoVA) on January 24, 2009 at 1:01 AM
  This message has been viewed 295 times.
In Reply To Fuel Pump Question on 2+2 NA -> 2+2 TT Conversion posted by Nick(CT) on January 24, 2009 at 12:02 AM
Message To use the TT controller you have to also be using a TT ECU module (not just a TT chip in a NA Module)
If you are using a TT chip in NA - use your NA controller.
If you are using a TT chip in a TT ecu - you can use the TT controller.
You will need to add a wire to the controller connector on your cars chassis harness.
Depending on what EFI harness you are using (TT or NA) and IF your body harness is wired for it (Adam's 93 NA Vert had the wire already in it) so when we installed a 95 EFI the TT controller was a simply plug & play.
Otherwise you run a wire from the ECU connector to the pump controller.
SILVER HI Overdrive Water Pump Pulleys Are Here!
Bernie
Need SERVICE, DIAGNOSTICS, or PARTS in the NoVA/DC/MD area?
