TwinTurbo.NET: Nissan 300ZX forum - Fuel Pump Question on 2+2 NA -> 2+2 TT Conversion
Subject Fuel Pump Question on 2+2 NA -> 2+2 TT Conversion
Posted by Nick(CT) on January 24, 2009 at 12:02 AM
  This message has been viewed 685 times.
Message I want to swap the stock NA 2+2 fuel pump and fuel controller for the TT fuel pump and TT fuel controller for this 2+2 TT conversion. But here's the problem I'm running into, so I need some help from those of you have done this successfully:
The TT fuel pump has different electrical connectors & a dual-float setup not found on my stock NA 2+2 setup. Also, while test fitting the TT’s pump & dual-float into my NA’s gas tank opening, there are clearance issues inside the gas tank that are preventing the TT setup from sitting into the tank – it feels like it’s bumping into the inside baffles of the tank directly below the fuel pump access panel – which I’m guessing is due to the different gas tank shapes of the NA vs. TT.
Should I just swap the actual fuel pump from the TT's dual-float setup onto the NA’s single-float set-up, along with the TT’s fuel controller? Will it work correctly? Here are the pics. Thanks in advance.
TT fuel pump with dual-float setup and TT fuel controller
NA fuel pump with single-float setup and NA fuel controller
