TwinTurbo.NET: Nissan 300ZX forum - My results on TPS.
Subject My results on TPS.
Posted by 96300NAZ on September 22, 2008 at 5:29 PM
  This message has been viewed 304 times.
In Reply To Suggest checking doing the simple cheap things first to > posted by ZUL8TR on September 19, 2008 at 08:30 PM
The continuity on the switch checks out fine.
The switch on a 96 is different than that of the one in the tutorial,
However, going by the tutorial i've measured across the orange/blue - black = 5v
Black - Black = 0v
Sensor plugged in, ING on:
(This was measured via the plug to the TPS, which does have red/white/black)
White to ground at closed position = 5v.
It does not change or fluctuate regardless of what position the throttle is at. I have not attempted to adjust it because it is so far out of spec and it didnt fluctuate.
