TwinTurbo.NET: Nissan 300ZX forum - Re: A/F Base # , O2 sensor # on Datascan and a few questions
txq45
on September 22, 2008 at 2:16 PM
posted by Z Driver
on September 22, 2008 at 12:25 PM
Check your tps for less than .5
The aac should work at 15% but check it after everything else has been done.
A/F is done by a AF controller or tuning on a dyno
MBC dropping usually means the spring is to weak...
Z Driver
12:25:56 09/22/08
As far as the boost falling off
FuerGrissa
13:41:31 09/22/08
Re: As far as the boost falling off
Z Driver
13:56:17 09/22/08
same boost problem
ricky6991
15:10:50 09/22/08
Does your MBC only have one knob?
FuerGrissa
17:37:57 09/22/08
yes it has a knob, 1 inlet, and 1 outlet....that's all (n/m)
Z Driver
21:42:30 09/22/08
profec is a huge diff.... install it you will see. (n/m)
ricky6991
22:05:28 09/22/08
Let me see how many of these I can answer...
kkrofft (OH)
14:10:17 09/22/08
Thanks for correcting my mistake (n/m)
FuerGrissa
17:41:33 09/22/08
I did keep WOT for a period (at least a few seconds after
Z Driver
22:08:21 09/23/08
Re: A/F Base # , O2 sensor # on Datascan and a few questions -
txq45
14:16:13 09/22/08
boost could be falling off from a boost leak after
The Devils Z
20:52:36 09/22/08
I dont think I have a boost leak because my MBC will hold
Z Driver
22:05:16 09/23/08
Yes (n/m)
The Devils Z
07:29:58 09/25/08
