TwinTurbo.NET: Nissan 300ZX forum - Since the rear HICAS is a hydraulic cylinder, you'd have to
Subject Since the rear HICAS is a hydraulic cylinder, you'd have to
Posted by LitlElvis on September 21, 2008 at 9:48 AM
  This message has been viewed 111 times.
In Reply To Can I eliminate the steering hard lines without removing... posted by OriginalGate21 on September 20, 2008 at 10:13 PM
Message assume that leaving it in there with no pressure (and a leaking line), that it will eventually bleed enough oil, become loose and not control the toe of the rear tires at all.
To be safe, you need some sort of a solid replacement for the HICAS cylinder *OR* a properly functioning HICAS cylinder with no leaks.
