TwinTurbo.NET: Nissan 300ZX forum - boost leak test = smoke
Subject boost leak test = smoke
Posted by ricky6991 on September 20, 2008 at 5:57 PM
  This message has been viewed 184 times.
Message i did boost leak test today. found one on throttle body then i notice a really big one...
the intake manifold gasket im assuming.
it only hits 3psi wiht the tester and goes strait down to zero. so i did it afew times to see if any others and just that one big one. so a plenum pull is going to happen wiht my 5spd swap as well as egr delete.
i put intake back together and a HUGE cloud of smoke came out of pass. side turbo. (i only have precats on the car at the moment and the pass side one i can take off my hand thats how loose bolts are cause gaskets shot) for about 10min of revving my car and letting it idle normal it was smokeing and burning oil. finally it stopped smoking... i drove it around hitting boost and no smoke. any possibilities.???
there was very small amount of oil in my pass side boost hose.
i have greddy prfec b2 installed but its been off untill my ecu arives. so im only hitting 5psi.
is there any vacumm lines that are under plenum that would make it be that big of a leak?
