| the HICAS in the rear? Basically the hardlines under the drivers side have a leak which is very difficult to repair and Im assuming its easier to eliminate them. Can I just bypass the fittings on the reservoir and disconnect them for now or I Need to remove the rear HICAS bar and put in the Stillen Eliminator in order to completely work? Just wondering if its possible to fix this for now before I can by the HICAS Eliminator Or if there are any suggestions on what to do on these 2 hardlines. Thanks
