TwinTurbo.NET: Nissan 300ZX forum - Is replacement harness an exact production match for>>
Subject Is replacement harness an exact production match for>>
Posted by ZUL8TR on September 21, 2008 at 6:25 AM
  This message has been viewed 98 times.
In Reply To Injectors will not fire need help posted by ricerdaddy on September 20, 2008 at 08:00 PM
Message your year or for a different year? Just because the main harness attachment fits into the ECM there may be different pin lications for the injector wires. Check the continuity from each injector harness to each correct ECM pin.
You note that there is 12v at each injector connector and that should confirm the power portion of the circuit. Is your replacement harness design one that is not 12v to the injectors unless the ignition is on? Was your original harness the same design?
ZUL8TR in Orlando,FL
