TwinTurbo.NET: Nissan 300ZX forum - Injectors will not fire need help
Subject Injectors will not fire need help
Posted by ricerdaddy on September 20, 2008 at 8:00 PM
  This message has been viewed 129 times.
Message Check the CAS which is good.
Check power Supply to the injector clip, Reads good Voltage.
Ran ECU code Nothing.
Is there any other way to check the grounding circuit.
This is after putting in a new ECU harness.
the only thing that I con think of is when I depin the big white harness connector to fit the ecu harness through the firewall.
ther two wires that are the same color Yellow with green stripe. I might of reverse it.
Any help would be appreciated.
