TwinTurbo.NET: Nissan 300ZX forum - probably should remove the diff and take it to a diff shop
Subject probably should remove the diff and take it to a diff shop
Posted by aliaZ on September 20, 2008 at 5:50 PM
  This message has been viewed 144 times.
In Reply To Leaking pinon seal on differential question... posted by serious on September 20, 2008 at 05:15 PM
Message You might be able to remove the pinion nut and just replace the seal. However, you run the risk of not having the correct preload on the pinion bearings when you reassemble because the crush sleeve is only supposed to be used once. Some shops reuse the crush sleeve and just loctite the pinion nut.
When mine started leaking, the diff shop disassembled the entire diff and put in a new crush sleeve to ensure the proper preload.
