TwinTurbo.NET: Nissan 300ZX forum - clutch problrms, any suggestions?
Subject clutch problrms, any suggestions?
Posted by Quick96tt on September 20, 2008 at 12:50 PM
  This message has been viewed 167 times.
Message I have recently installed (10k miles ago) a rps max street clutch and Im having problems with the clutch not releasing fully. I had this problem before i changed th cluth as well, It seems to get worse the longer you drive as though heat is making it worse. I have bled the fluid, installed ss clutch line, and adjusted the pedal. last night after an hour of stop and go traffic it would not go into gear unless engine was shut off and would idle at 500rpm or lower due to clutch drag. I was thinking the clutch fork is flexing, any other ideas or things to replace while im in there. thanks
