TwinTurbo.NET: Nissan 300ZX forum - Sounds like your differential may need to be rebuilt
Subject Sounds like your differential may need to be rebuilt
Posted by NytWolf on September 19, 2008 at 3:44 PM
  This message has been viewed 160 times.
In Reply To 300zx lsd differential question posted by ZXTREM3 on September 19, 2008 at 11:39 AM
Message Your pinion and ring gears are binding. That is what is causing the lockup when you stop. The cause could be bad bearings, whether pinion or carrier bearings. From your description, I don't think it's the gears.
The way to fix it is to rebuild it. You may be able to salvage the ring and pinion, but the bearings will need to be replaced.
