TwinTurbo.NET: Nissan 300ZX forum - If it had some oil in it, it may be ok.
Subject If it had some oil in it, it may be ok.
Posted by DVDBURN (MD) on September 19, 2008 at 5:42 AM
  This message has been viewed 134 times.
In Reply To I just looked at the ATF and it says not used in Dextron IV posted by MattMart1(NJ) on September 18, 2008 at 05:25 PM
Message If the torque converter was really low on fluid it may not fill properly. It needs to be primed before installation. Check your fluid level and refill as needed because the fluid level will start to drop after the torque converter starts taking on fluid after driving the car for a bit.
Just dive the car untill the torque converter starts filling from the other fluid and starts operating properly. If you have tried driving the car for a good bit of time with no change then either there wasn't enough fluid in the torque converter to get it to operate properly or there's something else wrong.
www.mytwinturbo.com
Watch an ECZA meet caravan!
