TwinTurbo.NET: Nissan 300ZX forum - Does it overheat when you are at a steady speed say
Subject Does it overheat when you are at a steady speed say
Posted by eriksu9 on September 17, 2008 at 3:59 PM
  This message has been viewed 194 times.
In Reply To Overheating - Any Ideas? posted by Mikester(Seattle) on September 17, 2008 at 11:59 AM
Message 40 mph and above? If it only does it when you stop, it is your fan clutch....If it does it even at speed, than you have a leak somewhere. By the sounds of the puff of smoke, you probably have a bad upper or lower hose from the rad or a coolant line or of course, the water pump. There is 2 small hoses behind the water pump which tend to go also. Are you low on antifreeze? If you are, there is a leak. start car and put a load on it and look at the waterpump to see if it is leaking..Hope this helps...
http://www.members.aol.com/eriksu9/images/1badz.jpg" BORDER=0>Hook up your Z here!
****472 RWHP/461 TORQUE ON 110 RACE GAS @21 PSI
****438 RWHP ON 93 OCTANE PUMP GAS/STOCK MOTOR****
****429 FT LBS/TQ*******************************
Also own:
2001 Harley Davidson Custom Softail Deuce
1997 Ford Explorer XLT V8 AWD
1993 300ZX 2+2 NA
1991 Yamaha YZ250
1985 Ford Bronco 3" lift, 35" Tires
Sold:
1986 Yamaha FJ1100
1987 Nissan 300zx na(Z31)
1979 280ZX 2+2
1972 MGB
1968 Pontiac Firebird
1972 Nissan 240Z, dual webber carbs, etc
