TwinTurbo.NET: Nissan 300ZX forum - Re: engine temp sensor is the coolant temp sensor..
Subject Re: engine temp sensor is the coolant temp sensor..
Posted by elcid on September 15, 2008 at 11:07 PM
  This message has been viewed 165 times.
In Reply To engine temp sensor is the coolant temp sensor.. posted by Drk93TT on September 15, 2008 at 10:34 PM
Message :the coolant is what makes the engine temp what it is.
:The yellow connector on the coolant pipe above the W.P. is the ECU sensor,
:the black one is for the actual gauge in the cluster.
:As far as the idle goes, sounds normal to compensate for more engine load
:with the fan on, then stabilizing.
THANKS FOR THE INFO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
