TwinTurbo.NET: Nissan 300ZX forum - sounds like your tires need to be balanced
Subject sounds like your tires need to be balanced
Posted by onewheelf4 on September 15, 2008 at 9:14 AM
  This message has been viewed 135 times.
In Reply To Vibration in Steering Wheel... posted by BrysZ on September 15, 2008 at 08:07 AM
Message If your brakes don't vibrate when you apply them, i would say that rules that out.
side to side movement of the wheel if you grab them at 9 and 3 and try to move it and it has play it is most likely a tie rod.
if you grab the wheel at 12 and 6 and it has play that way its most likely a ball joint.
Those symptoms wouldn't really cause a drive ability vibration while on the highway. They would be more of a sloppy feeling in the steering. You would prob also hear a clunk or thud every now and again.
I had a problem before that a cambered set of tired actually caused a vibration between 35-45 mph and would go away at any other speeds than that. Wheel bearings are also culprits. Not that that singles one thing out for you. But it does sound odd that the car only vibrates on the highway. Have you had the wheels re-balanced at all?
