TwinTurbo.NET: Nissan 300ZX forum - Re: Cometic head gasket problem
Subject Re: Cometic head gasket problem
Posted by Mike87T on September 12, 2008 at 9:45 AM
  This message has been viewed 188 times.
In Reply To Cometic head gasket problem posted by Gokussayien on September 10, 2008 at 12:08 AM
Message too much to read, but if you mentioned getting the head tested disregard this. Otherwise, I just pulled my passenger side head due to a blown head gasket, and I brought the head to a Napa to have it checked. They do a pressure test to check for cracks and also check the the mating surface to be sure it is 100% straight. $50 and well worth it. If you didn't do that, I'm sure that's the problem unless it is a cracked block which is more unlikely.
