TwinTurbo.NET: Nissan 300ZX forum - Re: Detonation / Knock sensor ohm test results...
Subject Re: Detonation / Knock sensor ohm test results...
Posted by Snowmansdsm09 on September 12, 2008 at 6:48 AM
  This message has been viewed 1601 times.
In Reply To Detonation / Knock sensor ohm test results... posted by Snowmansdsm09 on September 12, 2008 at 05:02 AM
Message After tons more searching this site, I have found more info.
"A quick rundown...the sensor side should read somewhere between 500k-1000K on one wire and infinite ( not connected) on the other. On the ecu side of the connector one connection shoule read ~500K ohms and the other side should be ground ( 0 ohms )."
So what misinformation have I read... is it between .500m-1m ohms or does it have to be right at 1m ohms?
I'm leaning more towards what this guy said up here. I'm really doubting it has to be 1M ohm or its bad. Reeks of misinformation to me...
