TwinTurbo.NET: Nissan 300ZX forum - Detonation / Knock sensor ohm test results...
Subject Detonation / Knock sensor ohm test results...
Posted by Snowmansdsm09 on September 12, 2008 at 5:02 AM
  This message has been viewed 672 times.
Message I read several post and the service manuals...
I tested my Det. Knock sensor on the 2M setting and it tested out .556-.567. So 1/2 a M ohm when it should be 1M ohm.
My only question; is the sensor supposed to be tested when hot or room temp? Sometimes it matters because resistance rises/lowers in different temps.
If not then its time to do the bypass till the engine is apart or out this long Alaskan winter. Whoooo Hoooo!
Thanks
