TwinTurbo.NET: Nissan 300ZX forum - Check the green 'ing' fuse located in the fuse box in front
Subject Check the green 'ing' fuse located in the fuse box in front
Posted by Samuel (Dallas) on September 11, 2008 at 4:26 PM
  This message has been viewed 149 times.
In Reply To Left the ecu in Dianostic mode posted by michaelsevilla on September 11, 2008 at 02:40 PM
Message of the battery. I had a similar issue as you..."When I put it on the "ON" position the HICAS, BRAKE, SEAT BELT, CHECK ENGINE. etc. etc. don't even cut on."
My problem was the 'ing' fuse didn't look like it burned out, however when I swapped it with the head light fuse (another green one just left of the 'ing' fuse) my HICAS, BRAKE, SEAT BELT, CHECK ENGINE powered on when the key was in the 'ON' position.
Courtesy Nissan wanted $6-8 per fuse. I went to AutoZone and bought the exact same 30amp fuse as Courtesy showed me for 2.99.
Check the fuseable link too (it's in the fuse box in front of the battery as well.) as it may have burned out. It's the blue fuse with a wire on it.
Good luck,
Samuel (Dallas)
91 TT
I had:well updated abit because I was so mad about what happened to my car...As of now its raining outside and I can't roll up the window on the driver side. I left the ecu in dianostic mode ....it smoked today when I was driving...now the car wont start. When I put it on the "ON" postion the HICAS, BRAKE, SEAT BELT, CHECK ENGINE. etc. etc. don't even cut on. My headlights still work and the car acknowledges me when I open the door. Could I have blown some fuses or relays? or just need a new ecu? Help me please.... I totally screwed up.
