TwinTurbo.NET: Nissan 300ZX forum - Re: Possible Fuel Injectors??
txq45
on September 10, 2008 at 10:31 AM
posted by DizzieLizzie
on September 10, 2008 at 10:08 AM
Check Ohm on injector and coil packs both. If smelling fuel on cylinders with spark you may have a bad cushion or o ring on the injector. If OEM injectors good chance it's the injector.
DizzieLizzie
10:08:50 09/10/08
Re: Possible Fuel Injectors?? -
txq45
10:31:07 09/10/08
Re: Re: Possible Fuel Injectors?? (n/m)
DizzieLizzie
13:54:50 09/10/08
Before checking ohms on injectors since removing the >>
ZUL8TR
12:07:25 09/10/08
2nd, this is a very usfull technique. (n/m)
1badz32 (MN)
03:08:42 09/11/08
...and put the stock plugs back in (n/m)
Audioquest
13:36:20 09/10/08
Mayor tune up!!!!
Neflyte
23:47:50 09/10/08
