TwinTurbo.NET: Nissan 300ZX forum - Because I didn't own a multimeter
Subject Because I didn't own a multimeter
Posted by FuerGrissa on September 09, 2008 at 3:24 PM
  This message has been viewed 133 times.
In Reply To Why not ohm test them through the ECU plug then? Really posted by Audioquest on September 09, 2008 at 08:01 AM
Message and some times I get peace of mind from just checking things out. When I was installing the plugs I jammed one of them into the adapter from my compression tester which I didn't realize was stuck in there and screwed up the tip. I tried to bend it back and regap it and I thought it would be okay, but I also wanted to check and see if this plug was fowling or having any problems since that incident. Gonna test the rest of the injectors when I'm off work in the mornign, I was just concerned to know if the discoleration on the plug was a bad sign is all.
