TwinTurbo.NET: Nissan 300ZX forum - Here's what I do to tighten properly. I adjust tension >>>
Subject Here's what I do to tighten properly. I adjust tension >>>
Posted by ZUL8TR on September 09, 2008 at 7:50 AM
  This message has been viewed 177 times.
In Reply To Re: Buy Goodyear gatorback belts never had one squeel. posted by elcid on September 07, 2008 at 09:30 AM
Message based on deflection with about 20 lbs load at the center of the span between the pullies as noted in the service manual. You don't want to over tighten since that will excessively side load the bearings and contribute to early failure of the bearings. Here is the on line service manual that you can search in for the specs. Look under maintenance.
[ http://300zx-twinturbo.com/cgi-bin/manual.cgi ]
If new belts are to be used you might have to readjust after several heat cycles.
ZUL8TR in Orlando,FL
