| Message |
After installing an RPS street clutch and Fidanza flywheel, I got the car back together and started it up. Now it won't go into any gear from neutral, and if I try to start the car with it in gear, it's stuck engaged. I only replaced the clutch disk, pressure plate and flywheel. Everything else was still intact and looked fine, and I didn't disconnect any of the clutch system lines, so there shouldn't be any air in the lines either. I've done a clutch install before, and this is the first time I've run into this problem. Any suggestions? I don't want to have to tear into the car again until I'm sure that's what needs to be done. Thanks!
Cheers, JBrobst
