TwinTurbo.NET: Nissan 300ZX forum - Re: Clutch
Subject Re: Clutch
Posted by forge on September 06, 2008 at 6:02 PM
  This message has been viewed 185 times.
In Reply To Clutch posted by Andreyev300 on September 06, 2008 at 03:25 PM
Message I had a problem similar to what you are describing; the clutch pedal had no resistance except for the last 10-15% of its travel. I ended up replacing both the slave and the master cylinders, which helped a bit but did not solve the problem. What finally worked was constant bleeding of the clutch system through the fender-mounted bleed screw; having a helper press and release the pedal was the only way to get all the air out. One-man, automatic, and suction type bleeders did not work at all. I hope this helps, good luck!
