TwinTurbo.NET: Nissan 300ZX forum - Pressure at idle should not be 43psi
Subject Pressure at idle should not be 43psi
Posted by lazer(AK) on September 04, 2008 at 2:58 PM
  This message has been viewed 116 times.
In Reply To Re: Why does this concern you so much? posted by harrybc on September 03, 2008 at 08:14 PM
Message If the fuel pressure regulator sees atmospheric pressure in the manifold then it should produce around 43 psi of pressure in the fuel line. At idle the manifold experiences vacuum so the fuel pressure should be around 30-35 psi depending on the condition of the motor and vacuum lines.
Additionally there should be no correlation between engine RPM and fuel pressure. The correlation should exist between manifold pressure and fuel pressure.
"The 300ZX Turbo is a dance; it's a song; it's rolling, roaring automotive art. There is no color that doesn't suit it. There is no mood-lifting chemical substance it can't replace." - Automobile Magazine
