TwinTurbo.NET: Nissan 300ZX forum - The shifter might be, but the real sensation is that the
Subject The shifter might be, but the real sensation is that the
Posted by RICH1 on September 03, 2008 at 10:00 AM
  This message has been viewed 119 times.
In Reply To Get under the car and check the mount. It's easy to tell posted by Audioquest on September 03, 2008 at 08:28 AM
Message driveshaft is binding up. For reference, this problem only started when I switched from the stock two piece drive shaft to the one piece Z1 Platinum. I think old mount (tranmission) were not worn enough to cause this problem to show up with the the two piece, where as it is with the one piece. Also, if I roll into the throttle smoothly there is no problem only when I just press the pedal to the floor does it seem to shutter. Keep in mind that with the new transmission mount, this effect is dramatically reduced but still slightly there.
