TwinTurbo.NET: Nissan 300ZX forum - I don't think it is a balance issue
Subject I don't think it is a balance issue
Posted by RICH1 on September 02, 2008 at 3:27 PM
  This message has been viewed 115 times.
In Reply To Re: Driveline Vibration posted by The Silent Genius on September 02, 2008 at 01:40 PM
Message so much as the driveshaft binding under heavy torque load. Going down the highway, it is a smooth as silk. I thought I read somewhere where the usual culprit is the tranmission mount, however if the differential unit bushings are worn, it can give a similar effect as well. The new transmission mount I installed was the OEM unit since a lot of people have stated that the NISMO transmision mount is too stiff. Courtesy Nissan sells the Nismo Differential Bushings but they are something like $80+ dollars each and you need two. I wanted to get some input from others before going this route. Nice Z's by the way.
