TwinTurbo.NET: Nissan 300ZX forum - What Dane said plus........
Subject What Dane said plus........
Posted by Greg D. (Specialty-Z) on September 02, 2008 at 2:50 PM
  This message has been viewed 126 times.
In Reply To Re: I know this is a long shot, but... posted by Dane (Houston) on September 01, 2008 at 02:47 PM
Message The exhaust can cause problems if you have leaks around the downpipe area. The reason this can cause a problem is because a leak near the downpipe will cause the 02 to be off from the air that will enter in the area of the leak. The 02 getting a false reading will absolutely cause idle issues.
The other items that Dane pointed out are all items that can cause problems as well.
:tight throttle cable
:throttle bodies not sutting all the way
:throttle bodies not synconized
:vacuum leak
:timing
:base TPS
:ECU temp sensor
