TwinTurbo.NET: Nissan 300ZX forum - Shifter bushing bolt.
Subject Shifter bushing bolt.
Posted by ChrisMedaris on September 01, 2008 at 8:51 AM
  This message has been viewed 139 times.
Message I've just replaced my shifter bushings with bronze and i'm now having shifting issues. I've searched and read that if the bolt is tightened too much then it becomes difficult to shift into gear. Well my issue is that when the car is NOT running i can shift through all my gears, but when i start the engine i cannot shift into any gears at all. Could this be the bushing bolt not allowing the clutch to engage?
I've also changed the clutch and pressure plate and bled the lines, so if it's not the bushing bolt then might it be the pedal adjustment? I've already crawled under the car and watched the slave as my friend pump the clutch pedal.
Anyone else have this same issue?
Thanks
Chris
